Why do only two of four MOSFETS get hot ?
hugoVS
Joined Jun 6, 2019
So I have made a H-bridge with two relay and four IRF520N mosfets. I control them with my microcontroller secured with an ULN2803. However when I connect +5V to the H-bridge board and +12V for the motors only mosfet T21 gets really hot and T22 als gets a bit warm. What could cause it ?
AlbertHall
Joined Jun 4, 2014
12,640
IRF520N needs 10V between the gate and source to turn on fully and be really low resistance. You are applying only 5V which means the FET will be higher resistance and hence dissipating lots of power.
38,668
Not reading the data sheet. :rolleyes:
The MOSFET's Vgs threshold voltage can vary significantly from unit to unit (see below), so ones with a higher threshold, will have a higher on-resistance with only a 5V Vgs, and thus dissipate more power for a given drain current.
Note the Vgs voltage of 10V for testing the on-resistance of the IRF520N (below).
You need a logic-level type MOSFET where the on-resistance is rated at a Vgs of 5V or less.
Alec_t
Joined Sep 17, 2013
15,149
Depending on your FET drive signals and the pick-up/drop-out times of the relays it seems to me that the relay switches K1 and K2 each provide a possible path for short-circuiting the 12V supply?
mlsirkis
Joined Aug 11, 2010
32
Read data sheet
Understand data sheet
Follow data sheet
hugoVS
Joined Jun 6, 2019
I only put a signal on the first relay and two mosfets with a delay to prevent shortcircuit . However these two didn't get hot.
hugoVS
Joined Jun 6, 2019
Vgs wasn't the problem why only two Mosfets got hot. I only controlled the first two Mosfets causing a floating signal on the other two, that's probably why they got hot. Now I control four of them and not a single one gets hot.
38,668
Okay, you lucked out with some MOSFETs that have a lower than maximum Vgs threshold voltage.
But for future good design practice, always use logic-level type MOSFETs if the Vgs control voltage is <10V.
