Some capacitors intended to serve as bypass capacitors, have 2 terminals to avoid any series inductance or resistance to the signal being bypassed. It makes good sense in theory, I am not certain as to how effective it is. Also, for a capacitor that large it would need more than two attachment points to adequately hold it to the circuit board. So it may also be a mechanical attachment option. Vibration can easily break component leads.Hi
Can you some one tell me the "B32776G8306" Parallel wire lead, 4-pin capacitor, this is 2 capacitor array or single capacitor with 2 parallel wire leaded capacitor.
Metallized Polypropylene Film Capacitors (MKP)
Rehards,
Vignesh.
by Robert Keim
