Who are you?
jsixis
Joined Apr 30, 2009
Old guy in Ohio who plays with electronics because it is fun. I also build speaker cabinets for both audio and live sound.
Nothing special just items that sound better then I can buy reasonably.
Hi everyone. I am a freshly graduated computer engineer from Pakistan. I love mcu programming and hardware designing. I have done alot of projects related to displays and analog sensor interfacing.
K.Green
Joined Oct 27, 2014
Hello everybody and thank you for welcoming me to all about circuits. K.Green
I am a student studying to be an Electrical Engineer I am a senior.
Hi all, I'm a plumbing and Heating engineer in London, England who is currently building a D class amp from a kit (41hz) and also a keen aquarist, and currently looking to build an algae scrubber, hence my appearance here to ask about wiring up 660nm leds.
Guest3123
Joined Oct 28, 2014
404
My name is Roy A., and I'm from Pennsylvania, U.S.A.
Just turned 32, and planning to build my very first circuit. I'm planning on buying the compenents needed to build a Voltage Regulated USB Cellphone charger using a LF50ABV VLDO Voltage Regulator IC, & a Turnigy 7.4v LiPo Battery (6.0Ah). Just came here because I was searching Google, and found this Forum, and was hoping someone could just lend a hand, and guide me a little. I'll stick around, and maybe I'll one day be as smart & knowledgeable as some of the people on here. Then when someone needs help as I once did, I'll have no problem helping them, if I can.
eric777
Joined Oct 28, 2014
Sorry. Am wrong person for advice. Am here for same reasons. Want to piggy back off a sensor circuit, add a timer and ldr sensor, and run some led garden path lights off a 12ah battery, have checked load 270mill amps at 10% duty cycle and should get about 12 days out of one charge before battery needs recharging....
35,195
Welcome to All About Circuits.
Use this "Who are you?" thread to introduce yourself.
Post general questions in the "General Electronics Chat" forum.
Hello, Im also electrical engineering student and I need some help in my embedded microcontrollers project
Post your question in the "Embedded Systems" forum.
Centera
Joined Jul 18, 2011
Hello everyone,
I am an it consultant from Holland with an audio amplifier hobby. During the day I work with complex IT infrastructures (mainly virtualisation and storage) and I spend most of my evenings working out circuits in spice or creating them so I can listen to them.
I am specialised in high voltage vacuum tube technology but since a few years I am now also playing low voltage with fet's. I design and build DC coupled amplifiers anywhere from a few watt's up to several hundreds of watts. I have explored many different amplifier topologies and amplifier builds and, at least for tubes, have now settled on my own designs.
At this moment I am working on two projects. The first is based on Nelson Pass' F5 amplifier, I have already worked out the schematics and I am now sourcing the parts. The second project is a 813 AB2 amplifier with a regulated B+ of around 1.5KV, for this one I will source the funds for a year before I can actually start building it ;)
Altyn
Joined Oct 29, 2014
Also I have already done some projects on 8051 microcontroller. If you wish you could visit my YouTube channel <SNIP> and ask me about codes:)
Mods-note: No self promotion on other sites please
Tester71
Joined Oct 29, 2014
26
Hello everyone. I am an Teleco Engineer and I like to build my little projects since I was a little boy.
Thank you very much for this very nice site.
I wish I had more free time to play with microcontrollers....I used some of them some years ago.....and I liked them very much.
darkroom
Joined Oct 30, 2014
18
Hi to AAC friends, i'm Darkroom, old-time Commodore BASIC/C/C++/x86/etc/etc programmer, musician, and DIY electronics hobbyist beginner; interested in digital and analog devices, started with computing and IT with the C64 back in 1985. I was always interested in electronics but now at my middle-30s i'm with enough time and space to learn.
Work in Wind Energy, and am looking for project advice in regards to LED lighting, PV generator applications for my Adventurewagon. As well as learning more about other aspects of electricity.
