Which is easier for PCB fabrication (corners)?
Gibson486
Joined Jul 20, 2012
360
Is it better to have rounded edges or 90 degree edges at the corners? Does the size of the PCB have an impact on this (like the smaller PCBs are better off having certain types of edges/corners)?
MaxHeadRoom
Joined Jul 18, 2013
30,801
If there is mounting holes in each corner, it usually looks better to use rounded corners that follow the mounting at the larger radius.
Max.
35,127
There is no single answer. It depends on your board, layout, signal, frequency, current, voltage, and application.
Lo_volt
Joined Apr 3, 2014
373
As cheap as PC boards are, it makes little difference in price unless you're making thousands of them. That being said, Max is correct, it's mostly esthetics. How do you think it will look?
