Which diode to use to prevent back EMF from a 12v mag lock
rickmcdonald83
Joined Jun 8, 2020
13
Really?!?
Wow - That seems crazy!
Obviously I'm ignorant to this, but that seems to me like touching the positive lead to the negative. ha ha.
I'll order the 1N4148 and connect it as you suggested. Thank you for all of your help!
dl324
Joined Mar 30, 2015
18,469
That's how a snubber diode works. When power is removed from an inductive load, the inductance will try to maintain the current that was flowing before power was removed. That will create a voltage across the diode that is the opposite polarity. A snubber diode limits that voltage to about 0.7V.
This how to draw your diagram as a schematic.
The resistance given for the inductor allows anyone reading the schematic to calculate the inductor current.
38,826
An inductor tries to keep the current flowing when you open the circuit, so it will generate a negative going spike on the positive terminal.
The diode across the coil provides a path for that current, limiting the transient to about -0.7V.
A diode in series will have no effect on that negative spike.
rickmcdonald83
Joined Jun 8, 2020
13
Thank you. I'm trying to understand this the best I can.
Did you see my crude wiring diagram drawings? Dennis said the drawing on the left would be the correct way to wire in the diode? Do you agree with that?
