Which diode to use to prevent back EMF from a 12v mag lock
rickmcdonald83
Joined Jun 8, 2020
13
Hello all.
I am experiencing back EMF from a 12v mag lock. I have read that you can use a diode to help prevent this, however all of the 12v diodes that I'm finding are 5 watt.
If I were to use a 60v - 5A diode, would this work? Would this cause any issues?
I am very new to this and still learning so I am open to any and all input. Thank you very much!
dl324
Joined Mar 30, 2015
18,469
Welcome to AAC!
The current in the diode won't last long and diodes with a lower continuous current rating could withstand significantly higher currents for short periods of time.
1N4001 will tolerate spikes of 30A:
If you don't want to do the calculations, use a diode with a continuous current rating the same or higher than the current in the device causing the back EMF.
rickmcdonald83
Joined Jun 8, 2020
13
Ahh good to know! Thank you!
I just looked up the specs. Here's what We have:
I have 2 - mag locks wired in parallel.
Voltage: DC12V
Current Draw: 0.11A ~0.15A
Do you think the 1N4001 would work for this?
peterdeco
Joined Oct 8, 2019
484
On very small current devices using low voltage, a 1N4148 often works. We also use 1N4001. On our larger 12V 5A DC motor we use FR603. High speed, high current.
rickmcdonald83
Joined Jun 8, 2020
13
Thank you very much for the input!
Would there be any disadvantage to using the 1N4001?
Just trying to understand what the difference between that and the 1N4148 would be.
I have a few devices including a couple linear actuators I will be installing diodes on as well.
38,819
Not really.
The main difference between the two is current rating, and the 1N4148 has a sufficient rating for your purpose.
The only disadvantage might be a slightly higher cost and physical size for the 1N4001.
You do know that the diode should be connected across the solenoid coil (cathode to plus side), not in series with the coil. (?)
dl324
Joined Mar 30, 2015
18,469
The only thing I could think of is appearing to be amateurish.
Some conservative designers would always derate components by 50%. Real designers do the arithmetic and make more appropriate choices. But 5-10X is unreasonable.
If you were stranded on a desert island and all you had was 1N4001, that would be different.
rickmcdonald83
Joined Jun 8, 2020
13
Thank you for the info!
Please forgive my ignorance, I am very new to this. Here's what I know:
The mag lock has a red and black wire coming from it. I have connected the positive wire from my 12v adapter to the red wire, and the negative wire to the black wire. From what I understand, the diode should be connected to the red wire. Is that correct?
peterdeco
Joined Oct 8, 2019
484
On high current inductive loads, the speed of the diode is important. Years ago some "genius" that worked for our company used 1N4001 on the 12V 5A motor we use. It used to get red hot. One by one every circuit board it was on was returned N/G.
dl324
Joined Mar 30, 2015
18,469
A diode has two terminals and polarity matters, so your description doesn't give us enough information.
The cathode of the diode should be connected to the red wire and the anode should be connected to the black wire.
Even for simple circuits, most would prefer a schematic to a verbal description. There's less chance for confusion; assuming you draw the schematic correctly.
