When should key appear on display?
mukesh1
Joined Mar 22, 2020
68
There are many systems that have a matrix keypad and an LCD such as calculator, password based door lock system.
i have general question.What should we keep in mind while designing such a system.
1. When should key appear on display?
if the key is first pressed or if the key is released.
2. What should happens if the key is pressed and held down continuously?
click_here
Joined Sep 22, 2020
548
It's very much a feel thing
I personally feel that a password based lock system or a calculator shouldn't repeat a key when held down, because they require precise inputs and there is no reason to put a random amount of a certain character.
atferrari
Joined Jan 6, 2004
5,026
The basic questions that come to mind:
Does the user need to see the result of the key just being pressed down?
Should the result be displayed at all? If so, for a short or long period?
I find obvious that if the result is to be displayed, it should appear immediately.
Your second question could be answered by deciding what YOU, the designer, need to happen when a specific key is pressed down.
BTW, adding confusion to your questions: what if more than one key is pressed simultaneously?
BobaMosfet
Joined Jul 1, 2009
2,211
This is a logic question.
  1. A key should appear when the user presses it, following a debounce to be sure the key is valid.
  2. If a key is held down- what do you want it to do? Repeat or not- that is your decision based on your needs. Repeating keys are fine, so long as there is a delay after the first press. Heuristics show that a person cannot react faster than a 10th of a second, so there is your window.
I've done this on many systems, and it works flawlessly.
35,114
There are three key-switch actions:
1) Key pressed
2) Key held down
3) Key released
For a large number of applications, the following functions should be executed:
1) Key pressed - debounce and display key icon. If the key is a function key, e.g. Enter, then the function is executed.
2) Key held down - no function
3) Key released - no function, except no new key-pressed is acknowledged until all keys are released. Again debouncing is required.
KeithWalker
Joined Jul 10, 2017
3,615
The answer to your question is:
You are the designer so the key functions should work the way you design them to work. How they work depends on the application and how you want them to work.
click_here
Joined Sep 22, 2020
548
Here is some very basic C with a lot of functionality missing, but you'll get the idea
Code:
for(;;)
  bool buttonPressed;
  //Wait for press
  do
    buttonPressed = isButtonPressed();
  while(!buttonPressed);
  handleButtonPress();
  delayForBouncingToStop();
  // wait for release
  do
  while(buttonPressed);
Basically, wait for a press, do something, delay for bouncing, and then wait for release.
