Sir I have a question kindly answer it out...
When BJT are used as amplifier and when FET are used as amplifier
The advantages of BJTs have however been somewhat eroded by progress in FET technology, and FETs also possess some particular advantages. The most important of these is their high input impedance (their gate currents are extremely low, often quite negligible). BJTs by comparison have lower input impedance, and require appreciable base currents. One downside of the FET's high input impedance is that it can be more easily damaged by static: only a small charge is needed to raise a damaging gate voltage.
FET amplifiers are therefore particularly useful where a high input impedances / low input currents are needed. Most of the lowest input current operational amplifiers are of this type.
I don't really think so - the reasons usually advanced for separating pre and power amplifiers have more to do with benefits and disadvantages of different parts of the system being close to each other, or well separated.And not to hijack the OPs thread but for us electronically challenged folks does this mean the use of an FET in an amp mean less need for a preamp?
The primary advantage of a FET in an amp is it's high input impedance so they are good for high impedance sources like some microphones. The lowest noise transistors are actually BJT which are good for lower impedance sources.And not to hijack the OPs thread but for us electronically challenged folks does this mean the use of an FET in an amp mean less need for a preamp?
So how did the handle this pre-FET? Just through additional circuitry to create a high impedance input tot eh amp?The primary advantage of a FET in an amp is it's high input impedance so they are good for high impedance sources like some microphones. The lowest noise transistors are actually BJT which are good for lower impedance sources.
Much earlier amplifiers used vacuum tubes, which also typically have very high input impedances!So how did the handle this pre-FET? Just through additional circuitry to create a high impedance input tot eh amp?
Not at all if you you want tone controls, balance controls, filters etc etc.And not to hijack the OPs thread but for us electronically challenged folks does this mean the use of an FET in an amp mean less need for a preamp?
