Wheel mounting
beatsal
Joined Jan 21, 2018
425
Trying to mount a 13X-5.00-6 lawnmower wheel on to a 3/4" shaft. Cannot find a suitable adapter for this purpose, any suggestions appreciated.
MaxHeadRoom
Joined Jul 18, 2013
30,771
A bit of a mechanical problem for an Electronic Forum!!
But sounds like you need a sleeve bearing to adapt one dia to the other??
Measure the two!
LowQCab
Joined Nov 6, 2012
5,101
There's no simple solution .........
If You can find a small local Machine-Shop, they can probably come up with
a solution for You, but the cost is probably going to exceed ~$150.oo, if they are feeling generous.
If You are trying to fabricate some sort of "Off-Road"/"Fun-Vehicle",
don't mess around with Lawn-Mower-Parts,
they will simply end-up breaking, ( at the worst possible moment ).
