whats this circuit?
absf
Joined Dec 29, 2010
1,968
If this is homework then the question should be :
"Find the value of V1 if VCC is 10V and get datasheets of the 2 transistors using Google.":D
Allen
GopherT
Joined Nov 23, 2012
8,009
Assuming the input is on the left, between the two 10k resistors, I would say this circuit is more of a power attenuator while at the same time, a voltage amplifier. Overall, i would say it is a mess.
dl324
Joined Mar 30, 2015
18,337
what is this circuit?what does it do?
An example of how to not draw a schematic??
It makes me cringe and wonder why the author didn't make any attempt to line up the resistors, use uniform spacing between transistors, and remove those unnecessary bends.
Aside from being useless...
OBW0549
Joined Mar 2, 2015
3,566
I would, but I'm too lazy. Just eyeballing the circuit, and assuming Vcc is around 10 volts, I'm thinking Q5 and Q6 are both saturated and the output at V1 is therefore something in the vicinity of 0.10 X Vcc.
#12
Dick Cappels posted my first thought (post#11). Then I ran the circuit (simulated) in my head and found it's a saturated output transistor. Now I agree with OBWO (post#9).
