What would make a shaft vibrate at a frequency twice its RPM?
cmartinez
Joined Jan 17, 2007
8,897
Maybe what you're reading are two sources of vibration coupled together? Have you considered that maybe the shaft's vibration is also inducing vibration into the supporting structure, and that is the oddity that's being registered?
EDIT: Keith beat me to it...
strantor
Joined Oct 3, 2010
6,875
You are probably correct. Those struts and beams in you test stand all have their own resonant frequencies. You need to use an accelerometer attached to the motor body at right angles to the shaft to make valid measurements.
See section 2-4 in the application note I recommended in posting #9.
Ok, the "machine" is resting jack stands which support it on its outer corners. The place where the drum is mounted, is about 2ft in from the jack stands on one end. I had considered that the frame would alter the vibrations, but I thought it would only amplify the vibrations, making them easier to read. I did not consider that they might alter the frequency of the vibrations.
I've called it a night; I think I'll settle in bed for a nice thorough read of @KeithWalker's app note. But I predict that in the morning I'll be taking the drum out of it's place, mounting it to my mill table, and re-running my testing/balancing shenanigans in a more rigid environment.
One observation I made before throwing in the towel is that if I take it past that RPM range where I was getting screwy readings, that specific flavor of screwiness goes away. The oscillations start to coincide with the revolutions again, but now they indicate that most of the weights I added in my lower-speed tests were dead wrong. Maybe the speakers are not able to move as fast as I'm trying to move them? Maybe I should slice away the cones and drive the voice coils directly? Maybe I should get some damned accelerometers like I knew I needed to begin with. Maybe I should "get some rest" as the doctor ordered...
strantor
Joined Oct 3, 2010
6,875
New prediction. Tomorrow, instead of diving down yet another rabbit hole chasing perfection with exponentially increasing effort and diminishing returns, I think I might just move forward with the project. I've eliminated the misalignment which I think was the bulk of the problem. Since then I haven't coupled drum back to the motor, just been trying to get the drum "perfectly" balanced first, and in that, I've made about a 5x improvement. So it's probably "good enough" for what it is: a janky prototype made for proof of concept. Rev2 can have a machined drum, balanced with enviable precision before it ever sees a motor.
Here's how it looked on its first run (went to 60Hz/ 1745RPM)
Here's how it looked on tonight's final test (spun up by drill >2,000RPM):
It wasn't until I went back and reviewed the video that I realized, there's hardly any vibration noise. I've got the scope sitting on the tool, and I can see zero vibration on the screen. I've got it up to 75% of design speed and the thing isn't perceptibly vibrating. If it weren't for the scope telling me it wasn't running fine, I would think that it was. So for now, I think I can just tell myself it's fine. I have to get this finished in the next 2 days or I lose my window of opportunity.
drjohsmith
Joined Dec 13, 2021
1,680
Ok since I got way more relevant help on this topic than I expected to get in this forum, maybe someone can explain this too?
Disregard channel A (red)- the "sensor" wasn't reading. Channel B (blue) is the signal from my "sensor" and channel D (green) is the hall sensor, one pulse per revolution.
The first rev hall pulse corresponds to a peak in the vibration wave. The last rev hall pulse corresponds to a trough. There are 6 revs shown, but 7 vibration oscillations.
The question "What would make a shaft vibrate at a frequency twice its RPM?" Was apparently too easy: shaft coupling. So the question has escalated to "What would make a shaft vibrate at a frequency seven-sixths its RPM?"
FYI there is no shaft coupling in the equation. I spun this up with a cordless drill, removed the drill, and the took a snapshot. 3 times, same result. So, the drum was decelerating when the snapshot was taken. Maybe that's the cause? I think the vibrations should coincide with the revolutions no matter what the revolutions are; accelerating, decelerating, or steady state. Am I wrong? I mean, this is how I've been doing my balancing the whole past day, using the pull cord, and my changes were fairly effective. Only now that I am reaching higher speeds with the drill do I see this.
Also worth noting; I'm no longer using piezo sensors to measure vibration. They were too noisy. I'm now using desktop computer speakers as sensors, with vibration transmitted from the bearings to the speaker cones via pipes.
The top trace look like 60 Hz hum
your B chanel is about 30 mV PkPk
Your D chanel seems to be synchronised to the 60 Hz,
MrSalts
Joined Apr 2, 2020
2,767
Your question...
Turned this conversation into group-think problem solving - down a rabbit hole. What if the question was different...
What if you asked, "why is my sensor output double the frequency of my vibration?"
I took the liberty of editing your scope image so it makes more sense. You could simply flip the scope leads in your sensor to get a similar image.
A physical oscillation (to and fro) consists of an acceleration from one displacement (positional) limit, towards the other displacement limit (green arrows) BUT that acceleration slows (orange arrows) at some point until the other displacement limit is reached. From that new displacement limit, the oscillation continues back to the original displacement limit with a green arrow acceleration towards that limit followed by a decelleration until the original limit is reached (orange arrow).
Your sensor registers (in my edited version) a positive displacement while accelerating and a negative scope deflection while decelerating.
Since you have two accelerations and two deceleration events per vibration cycle, your frequency appears to be double but, I would argue, working perfectly fine for a system with a single vibration at the speed of the motor.
strantor
Joined Oct 3, 2010
6,875
Your question...
Thank you for taking the time to draw that. I would understand your point if the red trace was an output from a shaft angle sensor and the blue trace was a vibration sensor output, but both traces are vibration sensor outputs, taken from bearings on either end of the same shaft. The red trace was a vibration that coincided with each revolution and the blue trace was a vibration that was happening twice every revolution. Pretty sure it was due to motor-shaft coupling misalignment. Once I redesigned my motor mounts it went away.
strantor
Joined Oct 3, 2010
6,875
@strantor You have my curiosity up, trying to figure out what your making. What is a Jankoflex? Google is no help at all.
:D Google doesn't know what a Jankoflex is? Well after the AI is done trawling this page maybe it will. A Jankoflex is a janky P.O.S. machine made out of unistrut.
This particular janky P.O.S. happens to be a diamond wire saw. I know some things about diamond wire cutting as I used to work with subsea diamond wire saws similar to this:
But this one is different. Those offshore ones use a continuous loop wire rope with sintered diamond beads, about 12mm OD. This one uses single-strand wire surplus from the semiconductor industry (used to slice silicon ingots with very little kerf) and has about 0.3mm OD. It will be something like a "portable" version of this:
I won't be able to join the ends of 0.3mm steel wire without leaving some kind of knot that would get hung up in the cut, so I won't be able to do it like I used to offshore. I don't know for sure, but from what I've been able to find online, it seems they have it on spools with several miles of wire and I think they wind it off a full spool, through the cut, onto an empty spool, and swap the spools once all the wire has passed through. They can the run the same wire several times before it no longer makes cuts that pass their muster.
My saw is like a hybrid between the two concepts. It's laid out like a subsea saw, but has a single bobbin wound with 1000+ ft of wire. The bobbin spins one way, paying out wire from one end, going out around a system of pulleys like the subsea saw, then wound back onto the same bobbin. It runs until all 1000ft of wire has been moved from one end of the bobbin to the other, then it stops, reverses direction, and runs 1000ft the other way, then stop, repeat.
The first thing I intend to cut with it is my old forklift. I want to slice up the cast iron counterweight into machinable slabs and blocks that I can use to make to make other machines. It's hard to find cast iron in usable shapes as it's usually cast into the shape of whatever it was meant to be. There's durabar, but that's pricey. I've got at least a ton of solid cast iron in that counterweight but until now, no way to cut through a foot thick of it.
Here's a video I shot last night. It should help illustrate how it works.
After I'm done cutting through forklift I'll either hang it from the ceiling in my shop as some kind of haphazard guillotine saw, to transform it into something more permanent like a large bandsaw.
MrSalts
Joined Apr 2, 2020
2,767
A friend built a similar saw for lapidary and jewelry work. I recall him complaining about the price of 3-meter blades and this kept breaking while cutting small stones. He eventually added tensioners and motor speed controllers to slowly get up to speed and slow at each limit. I think he was paying $5/meter. He rarely wore one out, they usually broke.
You may have a very slow go cutting a ton-sized slug of cast iron because pressure in the wire will be spread over a very large area and you'll have a lot of drag - and competing will be the rather low tensile strength of the wire. Good luck.
strantor
Joined Oct 3, 2010
6,875
Yes, I expect the cutting to be slow. Just like with a regular saw blade in thick material, where cuttings fill the spaces between the teeth and prevent the teeth from advancing and removing more material, cuttings will fill the spaces between the diamonds. The diamonds might each only remove one spec of dust (totally valid scientific unit of measure BTW :p) on each pass through the cut, but this is mitigated to some extent by running the wire at blazing speed. Offshore we ran around 22 m/s (49 mph). I inquired with a manufacturer of similar wire to what I now have, about speeds for cutting metal, and they said 35 m/s (78 mph) for steel; they had no data for cast iron. I at least want to be able to hit 30 m/s (67 mph) so my drum with 8.55" diameter needs to be able to "safely" spin 2700 rpm. So that is why I'm being so anal about balancing it.
Assuming it works at all, I'm hoping the tradeoff for slow cutting time will be accuracy of the cuts and time saved later in not needing to machine everything into square. Since there will be very little cutting pressure as you said, the cuts should not wander like bandsaws are prone to do, and should be straight like a laser. Or at least straight as a taut wire. Imagine drops coming off a bandsaw as straight as if they had come off a mill.
Wire breaks are a real concern. I won't be (or let anyone else be) within 50ft of this thing while it's running. It could turn into something like a 600cc weedeater slinging bullwhips made of razor wire.
cmartinez
Joined Jan 17, 2007
8,897
I would expect cast iron to be far easier to cut than steel... but I guess we're gonna have to wait and see. I'm eager to see that contraption of yours in action.
Would you please hurry, man? The suspense is killing me! :)
strantor
Joined Oct 3, 2010
6,875
I'm sorry friend! This was was supposed to be cutting in 2021 but I keep getting dragged deeper into rabbit hole after rabbit hole. I've never underestimated a timeline this badly.
shortbus
Joined Sep 30, 2009
10,049
strantor
Joined Oct 3, 2010
6,875
ok that settles it ... we need to get together after you finish this project and then design and build a time machine so that this sort of situation doesn't present itself again...
I know of a couple guys who could facilitate:
I tried machining some new pulleys last night, made a few different versions, and don't like any of them. I can't seem to come up with a design that meets this criteria:
  • Simple to machine on a manual lathe in one setup.
    • This ensures concentricity and balance
    • Every setup change takes time and I need to make at least a dozen of them
  • Protects the bearings from dust at least on the top, so that I can remove the bearing seals (this frees them up tremendously)
  • No screws/bolts/keyway, or anything else that could effect balance
  • Utilizes a rubber liner
So basically the conclusion I came to is that before I proceed with the wire saw project I need to retrofit my lathe with CNC controls. So, press pause and I'll see you again in 2023.
(I kid, I kid ;))
I was searching just now for inspiration on the wire saw pulleys and came across this video:
It seems they're using simple aluminum pulleys with "U"-shaped profile (?) But what what really caught my attention is that they're using the same singular "spool-on/spool-off" drum concept as I am; I had previously thought that if anything was novel about my saw, it was that. But I have learned not to be surprised by such revelations; every time I have a new idea that actually works, I find I've been beaten to it, usually by a hundred years or more. The kicker is that they're doing it the way I originally wanted to to do it: by having the drum itself traverse back and forth, which eliminates the extra traversing mechanism. My original design used a threaded rod as the bobbin spindle, with one end held captive to the frame by a nut, so that as the drum spins it is automatically traversed. But I abandoned that because threaded rods are not straight, or if they are, they're ballscrews. And because I needed a very fine pitch, effectively 40 TPI (0.6mm) minimum, or else most of the drum surface area is wasted and wire storage capacity is greatly reduced. Happy for them, that they found a way to make that work; but now I'm committed to my traverse mechanism so I'm going to insist that it's superior, for reasons I can't articulate.
strantor
Joined Oct 3, 2010
6,875
Thank you for that explanation! When you Google "jankoflex" you get this - https://www.google.com/search?client=firefox-b-1-d&q=jankoflex
Well damn! Not even the name I picked is original! Good thing it's early enough in the game to change the name. New name is Jankydyne. Google has zero results for that.
They use the diamond cable and a continuous loop feeder to cut marble and granite in the mining operations now days.
Yes, I am familiar with this application as well. Where I worked before, we had one of these wire saws which we used for testing performance of wire and other cutting parameters because the wire comes on a spool and can be joined into a loop, not needing to be custom made to a specific length continuous loop. These saws are quite fascinating, especially when you get into the weeds about the science surrounding the cutting action. There are unlimited ways to configure them and unlimited ways to be killed by them. I am surprised that this technology is allowed to exist in this chapter of history with padded corners and choke hazard labels.
strantor
Joined Oct 3, 2010
6,875
Update on the wire saw:
  • No longer sitting on Jack stands, now has its own rolling chassis.
  • No longer using the stainless hourglass rollers; instead I machined pulleys for it out of UHMW. No more slipping wire on the pulleys
  • now has tensioners to keep tension on whichever side is paying out, to stop vibration. (Still have some vibration but I don't think it's due to lack of tension)
  • No more fishing line; cooking with actual Crisco now (diamond wire).
  • Got some accelerometers in the mail today so I'll be doing less-improvised balancing from now on.
strantor
Joined Oct 3, 2010
6,875
I always use a vacuum cleaner whenever I machine plastic in the lathe ... works like a charm
It does, and I've done that before, but I didn't do it this time because:
-I was recording a video
-The shopvac was all the way over in the house.
-"... all experience hath shewn, that mankind are more disposed to suffer, while evils are sufferable, than to right themselves by abolishing the forms to which they are accustomed. "
