What type of motors and battery I should buy for long range terrain robot ?
eagle1109
Joined Apr 18, 2015
8
I want to build a long range terrain robot, not a huge one, maybe 30 cm x 30 cm or 40 cm x 30 cm.
I haven't built the chassis, but I'm planning to use metal chassis whether aluminum or steel sheets.
My concern now is that what type of motors and battery I should buy ?
1. Should I get 12V or 24V motors ?
2. Based on motors voltage rating, what type of battery I should buy ?
34,717
There are too many variables to consider before we can start specifying motors.
What is the total weight of the robot?
How will the robot be powered?
What is the maximum speed required?
How far will the robot travel and for how long?
What precision is required?
How will the robot steer?
How many wheels on the robot? How large are the wheels? What kind of wheels?
What kind of terrain will the robot traverse?
etc... etc...
WBahn
Joined Mar 31, 2012
32,780
This is like me asking you what size engine and gas tank I need to get if I want a long-range vehicle. Could you answer something like that? I sure couldn't. Without even considering numerous other issues, I would get expect very different answers if it turned out that I wanted the vehicle to do 120 mph for 1200 miles versus wanting it to go at 30 mph for 600 miles.
Jon Chandler
Joined Jun 12, 2008
1,581
Electric wheel chairs can sometimes be found at thrift stores pretty cheaply. I know several people who have converted them into robots. This might be a good starting point for the propulsion system.
eagle1109
Joined Apr 18, 2015
8
I have no experience with weighting rc robots, considering the weight of the metal chassis + motors + battery + electronics.
But let say max 3 - 4 kgs .. if my assumption is logical.
Using a big capacity battery, but I'm not sure what to use.
Didn't know that batteries are really expensive.
Good quality Li-ion packs; like, Molicel would cost me a lot
Also, I'm thinking about li-fe but don't know which type to choose because the ones I get in search results are really expensive like $1400.
Not very important, any speed but not too slow, because I'm doing it for exploration and testing long range electronics.
If I'm sending it to a far location it should be a reasonable speed where not to draw the battery so fast and not too slow so I wait a lot of time until it reaches the target location.
I'm thinking to start within 1km not more than that.
Precision in in movement or in communication or locating it in GPS ? I don't know what you mean.
But anyway in electronics part, it should work ok.
I would use skid steering like the tank.
I think 4 is ok.
Not planning for wet situations, but I want to include that property in robot design that it can handle wet areas.
Also, other terrains; like, street and sand. That's pretty much what I have in the region I live in.
eagle1109
Joined Apr 18, 2015
8
What is ‘long range’ and how heavy is it.
Long range means, using a relatively big battery and long range transmitter/receiver electronics.
Basically a range within 1km is my first goal, then I might study if I'm interested in longer distance.
and are you planning on solar charging.
Didn't thought of that actually, but I won't mind it if I needed this technology.
eagle1109
Joined Apr 18, 2015
8
That would be difficult in the area I live in. Scattered spare parts stores.
I think I have to buy it online.
DC_Kid
Joined Feb 25, 2008
1,242
24v is a better choice. Less amps on wires means less wasted battery energy.
If you could find 48v motors and controls, you could series two 24v batts.
Batt chemistry choice depends on environmentals. LiIon are no good in very cold, as example.
I should've put a picture of the model of terrain robots I want to design.
The two lengths of aluminium profile on the top are typically 40mm square so this is quite a big beast! Do you have actual dimensions and have you selected suitable wheels/tyres? That's where I'd start, but I'm just an engineer....
