What type of motor is this?
cebrax
Joined Jan 30, 2010
26
Hello!
I have a motor that has a sticker behind it says
DC12V
MMA-6P2RAP
Japan
28May91NB
It has 4 pads on it on a small pcb. Two of them are - and +.
Others has no identifier.
When I give voltage to + and - leads, the motor turns, and I can control it by pwm.
I measure the voltage on the other terminals and they give 2 V with 5% pwm and 0.707 V with 100% pwm(5V). But the voltage is not stable, and has big hops.
And unfortunately I don't have an oscilloscope.
Any idea?
beenthere
Joined Apr 20, 2004
15,819
The DC12V gives the operating voltage. Those leads with the erratic (to a meter) output might be for a tachometer function. You would need an oscilloscope to see the output properly.
beenthere
Joined Apr 20, 2004
15,819
A search on the numbers MMA-6P2RAP turns up only this thread. You can always use it as a 12 volt motor and ignore the mystery terminals.
cebrax
Joined Jan 30, 2010
26
My friend bought it to me and yes, he says that he saw motors like this in an old tape something(player or recorder, i dont know, he doesnt remember).
So how can I make use of these other two terminals? Any ideas? Trial-Error steps?
R!f@@
Joined Apr 2, 2009
10,014
That motor is simple to operate.
You give 12V to ± inputs.
The other two are High and Low, they are used for high speed recording modes.
With 12 V applied you have to give another voltage to either H or L.
U can use a 470 Ω 0.5W resistor from 12V to H or L.
Low will give a low rpm and H a high rpm.
I hope you did not damage the motor by jumping voltages between the pins. :D
