- Joined Jan 23, 2018
- 27,943
OK, that makes sense about the link, and it also means that you should be able to establish a radio link using the CAN BUS communications protocol. THAT part may be an interesting challenge. One caution is that the 433 MHz link is located within the amateur radio assignment and so you will need an FCC issued amateur radio license to use that frequency band. There are license free CAN BUS communication modules available in some of the license free bands, so that may be an option. The benefit is that you would have the control head already, not needing to do any redesign effort. So I suggest investigating the requirements for using the 433 band before transmitting, at least in areas that the FCC has authority over.Thank you MisterBill2.
Let me make my project a little more learn.
I am trying to modify a old Power wheelchair as a RC control car. I want to use the motors and the control unit which employ a Hall effect joystick to control the chair speed and direction.
Here what I want to do is to replace the Hall effect joystick by a Arduino joystick as the link above. But the unit did not recognize the new joystick.
the link from the controller to the drive package is a 6 line cable use CAN BUS. I am using 433MHz RC control pair.
