what should i use as opamp input signal as i do not have function generator?
kaman
Joined Feb 12, 2011
Hello ,
i do not have function generator to generate various waveform that is needed to be provided to the input of opamp circuit.What should be the input signal? and how can i view the output signal on cro?
38,802
Hello ,
An op amp circuit can have thousands of variations.
Which one is yours? o_O
What type of testing do you need to do, functional or performance?
What do mean, how can you view the signal? :confused:
You just connect the cro input probe to the output of the opamp and adjust the vertical gain and horizontal sweep speed to see the waveform.
Alec_t
Joined Sep 17, 2013
15,156
The ubiquitous '555 IC can be used to make a simple triaangle/square wave generator. Gazillions of circuits online.
simozz
Joined Jul 23, 2017
170
(...) that is needed to be provided to the input of opamp circuit. What should be the input signal? and how can i view the output signal on cro?
What circuit are you referring to ?
Why don't you post a more complete and detailed answer, explaining what do you want to achieve, perhaps with a schematics ?
simozz
