What results from Forward voltage drop of diode? And multiple bilge pumps
sdowney717
Joined Jul 18, 2012
711
I understand it need that much voltage to conduct.
Does this mean it looses that voltage on the output?
So if you had 12vdc going in, and FVD is 1.5v, then you have 12-1.5 = 10.5 vdc only after the diode?
I am interested in a bilge pump boat circuit where there are 2 pumps, 2 automatic float switches, and 1 manual switch.
The 2 schematics I was given are here, I can use two 12 vdc cube 40 amp relays, but what could be used for the diodes in the other schematic?
FS =float switch
BP = bilge pump
(The cathodes are not connected)
21,227
You are correct. The forward drop of the diode reduces the voltage seen by a load in series with the diode. A Schottky diode may be used to reduce the required forward voltage drop fro the same amount of current. The forward voltage drop will increase the more current you pull so watch the specifications carefully.
#12
faley
Joined Aug 30, 2014
88
Odd circuit. Usually float switches control relays and the relays carry the load. Also, it's not uncommon to see an alternator employed to control the primary. (I assume one pump is low level and the other is high- or are they not co-located?) Why the diodes? If the relay were to be electronically controlled, I could understand a free-wheeling diode across the coil.
sdowney717
Joined Jul 18, 2012
711
Wondering about startup motor surge, and what minimum you think is ok on the diode ratings?
So put multiple diodes together to reduce the burnout risk?
sdowney717
Joined Jul 18, 2012
711
These are 2 emergency use backup pumps. I have a primary low level, so these are higher level pumps. All the pumps on boats I have seen just wire float switches directly inline with their pumps.
primary is Rule 2000 GPH
backups are Rule 3700 GPH
Keeping voltage as high as possible to pumps keeps the GPH up as high as possible.
#12
I figure 8 times the run current for a start surge. That's why I keep listing parts with surge capabilities in the hundreds of amps.
sdowney717
Joined Jul 18, 2012
711
Would putting multiple diodes in parallel lower the forward voltage so the pumps get more power?
How many diodes could you put together?
Would that add a safety factor in case a diode failed?
#12
Yes, parallel diodes will share the load and have less voltage drop. You can save about a tenth of a volt for every parallel diode, up to about 4 diodes.
You can put 10,000 diodes in parallel, but that won't fix anything if one of them fails in the shorted condition.
