What measurement are you actually getting? "0.491" on a 2kohm scale aka 2000ohms could be 491ohms. Can you try measuring with different scale settings, assuming that these are manually set?.I'm still learning about this stuff, so should I swap those out? Should they work since they aren't registering at .2 ohms?
And who said anything was 0.2 ohms? That is an extremely low resistance, pretty much an impossible resistance to measure accurately with simple meter probes.
Note also that you cannot realistically "swap them out" until you know what they are. Removing one or both to measure out of circuit would be another matter, but if they are damaged the results may be inconclusive.
I'm also a bit sceptical about the chance of a resistor itself shorting down to less than 0.2ohm. It may be possible, but it is normally rare apart from with metal bodied types. More likely the short would be elsewhere.
I await developments with interest.
