what kind of micro controller is suitable for call with home phone network (NO SIM-CARD)
dashhossein
Joined Jul 30, 2020
49
hello everyone , for a educational goals i want design a security system which work with PIR sensor,
application is after detection of movement the processor will calls to a number that defined ...
i know approximately everything except module for calling ...
i don't know how the application of home phone networks (which work with RJ11)
what kind of micro and modules is suitable ?
could anyone help me pls ?
Beau Schwabe
Joined Nov 7, 2019
186
I assume you mean "old school" land line style telephones.
Almost any micro can produce the proper DTMF tones but a proper interface to the phone line itself will also be needed.
Even if you don't use DTMF you can interrupt the phone line in a make-break configuration to "TAP-OUT" the numbers like a rotary dialer ... 1 = 1 pulse 2 = 2 pulses 3=3 pulses .... etc.... except 0 = 10 pulses
But again you will need a proper interface to Pickup the Phone line (A relay can suffice) and some kind of Audio transformer to send a recorded message and/or your DTMF signals.
