What is this; Transistor or Diode?
Tonyr1084
Joined Sep 24, 2015
9,744
Meet transistor #Q615. It's labeled as C114 TSC but when I googled it I came up as a possible diode. On Digikey it looked more like a BJT transistor. This is from a Sony Stereo. This board controls the 3 CD player. This stereo has been scrapped and I just wanted to play with the bi-color LED's. If they can suit a purpose I may incorporate them into my truck. Details on that are unimportant. What I'm trying to do is figure this board out. Below is a schematic I made from following the single layer traces. It's pretty straight forward but could use a little help identifying two things about this board: 1) what voltage are they sending to the LED's? And 2) What type of control device is Q613, Q614 & Q615? (Q615 in picture)
debe
Joined Sep 21, 2010
1,415
Its a 2SC114 transistor Vcbo 50V, Ic 200 ma,Pc 750 mw. Had to look it up in a very old Japanese transistor manual as google wasn't very helpful. Going by the resistor values for the LEDs around 5 to 6V DC.
Tonyr1084
Joined Sep 24, 2015
9,744
Wasn't sure if they were BJT's or some sort of FET.
No, I only tried C114. I'll try the 2SC114 and some variances of it.
As for voltage, I'm going to guess that they want to use 10 mA as a starting point. These lights were not intended to be bright, just to indicate which CD was being played, CD1, CD2 or CD3. Since they are bi-color I'm assuming there was some meaning to different colors, hence pins 4 and 5 appear to set up which color would be used and the transistors would determine which light was on at which instant. AND I don't even know what colors they are yet.
Pins 1, 2 & 3 appear to be connected to a "Gate" on each Q. Since it's on the side of the device I thought it might be a FET or MOSFET, but if it's an NPN then shouldn't the base be the center pin of Q615?
Searching through using expanded numbers I found http://www.onsemi.com/pub/Collateral/DTC114Y-D.PDF, which appears to have built in internal resistance. Closest thing so far, but still bewaffling me.
Tonyr1084
Joined Sep 24, 2015
9,744
Holding pin 6 low and driving pins 3, 4 & 5 high (5 volts) Both D631 LED elements illuminate. Pin 4 drives the yellow element, pin 5 drives the green element. It would stand to reason that pin 2 high would light D632 and pin 1 lights D633.
