What is this thing?
27,501
I was going to suggest connecting an ohm meter to which ever pins looked connected on the inside. That device may have been the sensor in a beam-break security system in the early 1950's era.
Reloadron
Joined Jan 15, 2015
7,886
It's a photo sensitive vacuum tube or valve for those across the pond. Commonly called a Photo Tube. During the late 50s and early 60s my dad used them in many of his packaging machine designs. I haven't seen one in many years but that is my guess.
Here is an example which covers how they work.
Ron
27,501
I never had one of those, but I have seen the circuits. I think the rest of the circuit used either a 50L6 tube to drive the relay, and a couple of octal amplifier tubes, and a 35Z5 rectifier or a 117 volt heater tube that I do not recall the type number of.
27,501
That tube looks a little bit like the counter/display tubes I saw in a video that showed the early KRONDECK time counters used for timing drag races a while back. Around 1960, possibly.
