What is the value of this crystal oscillator?
Reloadron
Joined Jan 15, 2015
7,975
Your title says "crystal oscillator" but the image looks like a common quartz crystal and if it only has two pins very likely is a crystal and not a crystal oscillator. No way to really tell from that part number what frequency it may be.
Ron
28,486
If it only has two terminals then yes, it is a crystal. The oscillators that size have 4 terminals.. I could not make out any details of the image posted, others may have a much better video display and be able to read it very well. I do have some crystals that look like that, which means nothing at all.
I hope that this is not an old post thgat I am replying to.
28,486
Clearly I did miss that fact. How similar is similar?? If it has 2 terminals then it is just a crystal, but if it has four, then it is probably an oscillator device. A package that size is probably in the megahertz or tens of megahertz range, it is too small to be a low frequency crystal. If an oscillator, the power would be either 3.3 v or possibly 5volts, no telling without using the part number.
BobTPH
Joined Jun 5, 2013
11,665
Really? Then these must be in the Gigahertz range.
Actually, they are 32,768 Hz.
Bob
