Was he asking about small welds, or small welders?Arc welding is not simple! First, there must be enough voltage to strike the arc, then immediately there must still be enough voltage to maintain the arc while there is enough current to provide the wattage (POWER) to melt metal to create the weld. Not as easy as it sounds, if the goal is good weld quality. THAT SOUNDS COMPLICATED BECAUSE it IS complicated. Certainly there are quite a few people skilled enough to consistently produce very good welds consistently. I am not one of them. But with a decent wire-feed, gas shielded welder I have producedadequate welds.
The field welders dream. Lite weight and doesn't require power. But doesnt perform either! Performance comparison ... beyond not even close.Hello all.
They were big monsters :
And now I see these :
View attachment 365828View attachment 365829
Can someone explain ? Are these 'chinese amperes' ?
It's a welder manufactured by Hobart. The name Hobart is partially viewable in the image posted.If that unit is a welder and not simply an AC generator,
| Thread starter | Similar threads | Forum | Replies | Date |
Patrick Stuart has died. RIP | Off-Topic | 2 | |
| S | Sealing heatshrink tube of optocouplers | General Electronics Chat | 16 | |
A Neat Trick – Using Phone Link for Copy/Paste | General Electronics Chat | 0 | |
Tricks and Tips Y2026 | General Electronics Chat | 4 |
