Does it mean the dimension determine the ohm resistance?It's copper μstrip. Part of the PCB. The paper where you got the schematic should have the details on their dimensions.
No. It means impedance measured in ohms.Does it mean the dimension determine the ohm resistance?
Google stripline impedance.
Thanks all the help i will have a read firstHello,
Perhaps the attached PDF's might give you some ideas.
Bertus
Is it possible a coaxial cable as alternative replacement for the microstripline?No. It means impedance measured in ohms.
Sure... as long as you can get coaxial cable in as many Zo's as your circuit calls for.Is it possible a coaxial cable as alternative replacement for the microstripline?
ThanksSure... as long as you can get coaxial cable in as many Zo's as your circuit calls for.
by Aaron Carman
by Aaron Carman
by Aaron Carman
by Jake Hertz
