what is the power dissipated in 2 ohm resistor?
33,201
This is the Homework Help, not Homeword Done For You forum. So you need to show whatever work you have done in your best attempt to date to solve the problem. If nothing else, describe what you think the approach needs to involve, even if you don't see how to bring it all together just yet.
33,201
correct answer is 3W , :confused::confused::confused:
Yeah, I came up with that doing it in my head and almost as soon as I posted that I realized that I had screwed it up because one of the cross terms doesn't go away. I get 12W, the same as you. I got this by performing the square on the three terms directly.
I've confirmed that you combined the two trig functions properly and I, too, get that the current is
i(t) = 2A+2A*cos(2t)
I even plotted it in the time domain in Excel and found the average power numerically and got 6W.
So I think that your answer is correct. I don't know how they are getting 3W.
Actually, I think I do. If this were the voltage across the resistor, and not the current through it, then you would have 3W.
33,201
Yep. I think the author just screwed up and divided the square of his function by 2 instead of multiplying it by 2. The reason the mistake didn't get caught is because the author can't be bothered to track their units, so they forfeited the ability to spot the problem.
