What is the input capacitance of BD135
MrAvlund
Joined Nov 27, 2023
My question is quite simple; can someone tell me how I can read the input capacitance of this transistor?
https://www.onsemi.com/pdf/datasheet/bd135-d.pdf
For some background if needed:
I have built this circuit and found through trial and error that C1 (Cf in formula) works best for my circuit at 10pF.
https://www.ti.com/lit/an/sboa325/s...35663&ref_url=https%3A%2F%2Fduckduckgo.com%2F
I am currently trying to explain the compensation techniques of a op-amp driving a capacitive load. The design is using a technique described by a reference guide by Texas Instruments.
The video can be found:
https://www.ti.com/video/series/precision-labs/ti-precision-labs-op-amps.html
I found one more reference for this:
https://www.proquest.com/docview/20...UxjsOWuCk=&pq-origsite=summon&accountid=11526
dl324
Joined Mar 30, 2015
18,504
I am a bit confused why the graph gives the capacitance vs the reverse voltage.
if my emitter is GND, Base is 0.7v and collector is 2v. Would I read the graph for Cib at reverse voltage 0.7?
It sounds like you want information that the manufacturer didn't provide. In that case, you need to contact the manufacturer.
BobTPH
Joined Jun 5, 2013
11,675
When the junction is forward biased, current flows steadily without building ip a charge, so it effectively has no capacitance.
Papabravo
Joined Feb 24, 2006
22,112
You could always get a nanoVNA and measure it as a function of frequency. I hear they are quite affordable. Much more so that an actual VNA.
MrAvlund
Joined Nov 27, 2023
Hello, I do have access to a lab with VNA etc. I am however not quite sure how you would approach measuring the capacitance. Would you approach it the same way as measuring a capacitor?
To me what bob said, would make the transistor act as a variable capacitor? (dependant on frequency)
Papabravo
Joined Feb 24, 2006
22,112
You fabricate a measurement jig where you can characterize the parameters of a part to show how a sample from the total population behaves.
