What is the Formula -RC series circuit impedance & current
ironasona
Joined Nov 12, 2020
53
Hello am kind of new to all the electronics .So I was told to measure the voltage across the capacitor and the current of frequencies between 1khz and 10khz
so i was wondering what is the formula to finding them
100ohm resistor
0.01uF capacitor
thank you
ericgibbs
Joined Jan 29, 2010
21,572
hi iron,
A resistor is a passive component, its resistance should be the same at all frequencies, so use Ohms Law.
What is the voltage amplitude of the 1kHz to 10kHz signal and is sinusoidal.?
E
ericgibbs
Joined Jan 29, 2010
21,572
hi,
Ohms Law equation, Amps = Volts/Resistance
So for 10V that's 10v/100ohms = ...............................Amps?
E
ericgibbs
Joined Jan 29, 2010
21,572
hi,
That's better, we are doing the resistor first as it's the easiest.
So, 10v/100ohm = 0.1Amp as you say.
The capacitor is very different from a resistor as its impedance [ resistance] changes with frequency
You still have 10v across the capacitor BUT, the resistance is now Z= 1/ (2 *pi *freq * capacitance}
Do you follow that OK.?
E
ironasona
Joined Nov 12, 2020
53
ok so it would be 1(2*pie*freq*capacitance) but , what do i put in the freq, is it HZ/KHz and in the capacitance do i put uF/F or etc, or it doesn't matter? and then it would be 1(2*pie*1000*0.01)=0.01591? . 0.01uF and 1000Hz
ericgibbs
Joined Jan 29, 2010
21,572
hi,
If your tutor has asked you for all the current at ALL frequencies between 1kHz and 10kHz, you cannot be expected to give 10,000 answers.!
So choose 1kHz and say 10kHz
That would be Impedance[Resistance] = 1/( 2 * pi * F * C)
Z= 1/( 2 * 3.142 * 1000 * 0.01*10^-6)
Can you work out the Zohms value .???
E
ironasona
Joined Nov 12, 2020
53
hi,
Z= 1/( 2 * 6.28 * 1000 * 0.01*10^-6)
E
is it 7961.78343 ?
ericgibbs
Joined Jan 29, 2010
21,572
hi
Note I corrected the 6.28 to 3.142, I have got so used to using 2pi =6.28!!
So your answer should be doubled.:)
Z= 1/( 2 * 3.142 * 1000 * 0.01*10^-6) =15,923 ohms
So using that answer what will the current be for 10volts.??
E
ironasona
Joined Nov 12, 2020
53
hi
E
sorry you kind lost me there .The current for 10v will be 15,923ohms ? , am kind lost sorry
ericgibbs
Joined Jan 29, 2010
21,572
hi,
OK,
Use Ohms Law.
Current in Amps = 10V/15923ohms = ____________________.?
E
BTW: always use a letter to indicate the units you are using...eg: 15923 ohms
ericgibbs
Joined Jan 29, 2010
21,572
hi,
The number is correct, but why have you put V instead of A ident.??
0.00062802235V ?
Remember you are measuring current in amps.
0.00062802235A
Now do the 10kHz question, post your calculations.
E
OT: We Yorksire lads must work together...;)
ironasona
Joined Nov 12, 2020
53
hi,
0.00062802235V ?
0.00062802235A
E
Thank you so much ,you're an absolute legend .:)
