MisterBill2
- Joined Jan 23, 2018
- 28,253
I have come across steel wire with insulation that made it look like usable wire, I have come across coppery wire that undoubtedly contains some copper and other materials, and is under-sized for what the label calls it. The stuff described in post #20 was probably what is called "field phone wire", which may contain one copper strand. The strong springy strands are a steel alloy for mechanical strength, since it is intended to be used for military field phones, which use a relatively high line impedance and not much line current. It is amazingly strong, but mostly useful if you have military field phones. It is also useful for tying bundles of junk, if you have the means to cut it.
Aluminum wire for mains power distribution is ONLY used outside, where any hot spot connections will not start a fire in somebodies house. THAT is why it can be used. The cost is enough cheaper to make up for the cost of the wasted power.
