Thank you for your reply, I will ask about the specific specification parameters when I inquire about these two products.There are huge differences.
Call the manufacturer and find out what they recommend for Dimming.
Very good explanation, thanks a lot!If the controller expects the early part of each cycle to be (variably) cut, a triac would be an excellent choice. If it expects the later part of the phase is to be cut (which would be a rare case) then you need something you can turn off easily like a MOSFET or IGBT.
Most likely you need a triac.
Thank you!Thyristor control only works with AC.
MOSFET diming can be used with either AC or DC (depending upon its design).
MOSFETs are also more efficient for low voltage diming.
by Aaron Carman
by Jake Hertz
by Jake Hertz
