What is the difference between this two?
Can you tell the difference between this two?.
  • Total voters
geekoftheweek
Joined Oct 6, 2013
1,429
Probably nothing. I looked up the datasheet and glanced at it. The different numbers are probably lot numbers, date codes, or whatever for manufacturing traceablility. I didn't see them mentioned in the datasheet. The top number is the same which is probably all that matters... Unless someone who actually knows these things has something better to say.
#12
Joined Nov 30, 2010
18,224
One of them might be a TO-220 and the other is a TO-235 but that's about the packaging. One of them has its ears trimmed. The guts are the same.
WBahn
Joined Mar 31, 2012
33,261
What kind of part is it? I didn't find any part number with 1300 or 1300S or 1300SA in it on the ST site, but I might need to use an unprinted prefix or something.
Is it an IGBT, or MOSFET, or BJT?
The second might be a Chinese counterfeit.
ian field
Joined Oct 27, 2012
6,536
But first one with marking "CCOXC W" works well while second one is problematic.
Possibly country or factory codes.
Don't discount the possibility of counterfeit components - its less jail time than smuggling drugs.
So I'm told; buying from eBay is asking for it, but big name trusted suppliers get stung too!
A few years back, a big name got lumbered with 100s of thousands of latest new micros that turned out to be all package and no silicon.
WBahn
Joined Mar 31, 2012
33,261
The dealer says its 100% original.
He may be right or wrong i don't know.
Of COURSE the dealer says it's 100% original!
What else would they say?
If they know they are selling counterfeit parts, then they are in on the scam and will tell you that they are genuine parts.
If they don't know they are selling counterfeit parts, then they think they are real and will tell you that they are genuine parts.
I can't image a situation in which the dealer is going to tell you that the parts they are selling you might not be genuine parts. Perhaps after the fact and after they have gotten caught (or have found out) and are issuing some kind of recall (voluntary or mandatory).
WBahn
Joined Mar 31, 2012
33,261
It is 13005A and its NPN transistor
Ah. I thought the '5' was an 'S'. Thanks.
I didn't find any parts on their site with "13005A", but found three NPN transistors that had 13005 in them.
STT13005D
STU13005N
STX13005
None of them (at least using the table on ST's site) are available in a TO-220 case (or similar case with a drilled tang).
Looking at the DigiKey site, there is a ST13005 that IS in a TO-220 case, but it doesn't come up in the produce search on the ST site. But if I search specifically for ST13005 on their site I do get a datasheet for it. I've never been to impressed with ST's site, and this just reinforces that opinion.
Looking at THAT data sheet, it appears that the 'A' is a supplemental bin mark indicating that the DC current gain is between 15 and 32 (under the specified test conditions).
I didn't find anything about other supplemental package markings. It used to be pretty common that manufacturers would describe their full marking system, albeit perhaps not in detail (so you would know that XXX referred to some internal parameter category but not what that category was, or that YYYY indicated the production line but not how to decipher it further). Now that seems a lot rarer.
I tried searching for "Package marking" but their search returned thousands of documents (anything that had the word "package" apparently).
WBahn
Joined Mar 31, 2012
33,261
The ST13005A exists.
It is the ST13005 with the lower-wide HFE.
Bertus
Agreed.
But if you do a Product search on ST's site for ST13005, you get "No results found for: ST13005".
If you look at their Product Catalog for 500 V to 1000 V Power BJT transistors (the datasheet shows it is a 700 V part) and sort it by part number, they go from the ST13003 to the ST13007.
Yet DigiKey claims it is an active device (active as in in-production) and there is nothing in the Rev 10 datasheet (2012) to indicate it is obsolete or not for new designs.
I can't find any place on their site where you can get information about the production status of parts.
Once again, less than enamored with ST's website and datasheets.
WBahn
Joined Mar 31, 2012
33,261
Did you try 13005 only on the ST site?
I got this PDF :
http://www.st.com/content/ccc/resou...df/jcr:content/translations/en.CD00001235.pdf
Wich is the one (renamed) I posted.
Found on this search page:
http://www.st.com/content/st_com/en/search.html#q=13005-t=keywords-page=1
Bertus
Take your search and look at the Products tab to see what products they claim to have in their catalog that contain that part number fragment. You will see that it only lists the three that I mentioned before.
As I stated, if I search for ST13005 I can get the datasheet (in the Resources tab), but it claims that there are NO products with that part number.
It would seem that if they have a certain part, that it should be listed in their catalog.
If you were wanting to select a product and went to their product selection page and listed all of their mid-voltage NPN power transistors (they claim there are 36), you would not see the ST13005 listed, and hence you would never know that it is an option for your consideration.
Why would a company NOT want potential customers to see all of the available products?
