What is slew rate?
camerart
Joined Feb 25, 2013
3,853
I would like to know what SLEW RATE is.
I'm using a PIC 18F46K20 and controlling a TFT screen using SPI.
Thanks, C.
camerart
Joined Feb 25, 2013
3,853
Slew rate is about the rising and falling speed of a signal.
Most times it is used with opamps.
https://en.m.wikipedia.org/wiki/Slew_rate
https://www.electrical4u.com/slew-rate/
Bertus
Hi B,
I see !
I presume this applies to anything with a square wave, such as SPI signals.
I'm trying to figure out a PIC/TFT intermittent problem, where the TFT sometimes doesn't fire, but the PIC is still running.
Could it be cloned PIC or an error in the program/er or even a problem with the PCB?
C.
bertus
Joined Apr 5, 2008
23,014
There may be problems when a pulse is to slow.
The transition from high to low or low to high might take to long when the slew rate is to low.
Bertus
LvW
Joined Jun 13, 2013
2,038
The slew rate SR defines how fast the output of an amplifier with feedback is able to follow the corresponding input signal.
However, we have clearly distinguish between (1) small signal rise time and (2) large signal behaviour.
(1) The small-signal rise time depends on the small-signal bandwidth of the amplifier only and is defined also for amplfier stages without feedback.
(2) In contrast, the slew rate SR is defined for feedback amplifiers like opamps only.
It can be measured with heavy feedback applied (usually for closed-loop unity gain) and a square wave input signal that is able to bring the 1st stage of the opamp into saturation (feedback is not active due to unavoidable delays within the amplifier) - until the feedback effect brings the whole amplifier back to linear amplification.
As a consequence, in the first short time period the opamps first stage acts as a current source which loads the compensation capacitor of the 2nd stage. This effect causes the characteristic linear slope of the output signal caused by a the slew rate which is too small to follow the input signal.
This linear slope of the output defines the slew rate given in V/µs.
Comment: Any other effects (caused by a capacitive load, for example) have nothing to do with the slew rate.
camerart
Joined Feb 25, 2013
3,853
It can be measured with heavy feedback applied (usually for closed-loop unity gain) and a square wave input signal that is able to bring the 1st stage of the opamp into saturation - until (due to unavoidable delays within the amplifier) the feedback effect will bring the whole amplifier back to linear amplification.
Hi L,
As I don't know the ins and outs of the TFT, I don't know whether it has opamps or not, but SR has been suggested as a possible problem.
C
LvW
Joined Jun 13, 2013
2,038
Hi L,
C
Hi camerart, I am only able to give you the definition (and its theoretical background) for the large-signal parameter SR (slew rate). I cannot know If this parameter has any relevance for your application.
Question: What is the form of the output signal for a (ideal) squarewave input?
camerart
Joined Feb 25, 2013
3,853
Hi L,
I don't know how to answer your question, sorry.
C
camerart
Joined Feb 25, 2013
3,853
hi C,
Which TFT model, PIC, clock rate?
E
Hi E,
There are 2x TFTs on is ST7789
I'm using 18F46K20
We are changing the clock rate, until we get consistent result.
The question regarding slew rate is for my education, I have tested stuff and seen sloping square waves, and now I think I know what it is called.
C
sparky 1
Joined Nov 3, 2018
1,218
Sometimes imagery is useful in concepts for a visual thinker. I find it interesting that geometry
can help some to adapt a mathematic expression and gain confidence from past fear or math anxiety.
While some are struggling with algebra others are playing with numbers writing proofs not needing much geometry.
Others can visualize an animation of a gradual transformation in order to formulate a rate of change.
The picture below shows voltage over time. The formula shows voltage over time. As the numbers flow
through the Slew rate formula a change takes place as it approaches the Maximum slew rate.
With a periodic wave there is frequency. One of the Slew Rate characteristics is the frequency limit.
The expression for Slew Rate is
Have you ever wondered what electrical condition affects a sine wave to become more triangular?
Have you ever asked why a square wave starts to change shape to trapazoidal?
Good that is Slew Rate otherwise we chance opposition talking Geek to a Greek in figure b) ∀≠∃
camerart
Joined Feb 25, 2013
3,853
The expression for Slew Rate is View attachment 340373
Hi S,
Ok, that's clear.
C
camerart
Joined Feb 25, 2013
3,853
