What is my drill size of these LED holders?
spinnaker
Joined Oct 29, 2009
7,830
I am always challenged reading these dimensions on these drawings. What the heck is the drill size? They are LED holders for 3mm LEDs.
MaxHeadRoom
Joined Jul 18, 2013
30,645
No, it shows it at the rear as the push mount dia (5mm), once push mounted the rear compresses and the holder is mounted, it cannot be smaller than 5mm and larger with make it sloppy, once mounted.
You can always sacrifice one for a test run.!;)
Max.
spinnaker
Joined Oct 29, 2009
7,830
Max.
Still not seeing that dimension. Would you mind marking it? I really need to learn to read these damn things.
shortbus
Joined Sep 30, 2009
10,050
That is a very strange drawing. The one dimension that is critical isn't even shown. That dimension is, the straight part between both end, that would be the drill diameter. The end dimensions are what keeps it captive in the hole.
