What is happening in those wires?
Gerry Rzeppa
Joined Jun 17, 2015
170
Given the circuit below, with the capacitor previously charged to 100 volts and the resistor large enough so that full discharge will require about an hour:
Please describe the physical changes that take place in wire A and wire B during the discharge period.
Papabravo
Joined Feb 24, 2006
22,111
There are no observable physical changes taking place in the wires that I am aware of. Full discharge is of course an impossibility since the exponential decay to zero takes an infinite amount of time. You should phrase the proposition as: it takes an hour for the voltage to drop to 0.1% of it's fully charged value.
35,177
Since the wires A and B are subjected to the Earth's magnetic field, the wires will experience two diminishing forces in opposite directions given by the cross product of current times magnetic field.
Gerry Rzeppa
Joined Jun 17, 2015
170
The changes may not be observable, but we can measure their effects (say, with a voltmeter). So what are the theoretical changes in those wires during the discharge period?
You're correct. I should have said something like, "discharge to a state of approximate equilibrum", since the exact figures are not critical to the question.
Extremely slight increase in length and diameter due to a miniscule amount of heat release due to resistance?
Possibly, but I'm thinking smaller. I was hoping for something like, "At the start of the discharge period, wire B will have ["more electrons" or "electrons that are vibrating more quickly" or "electrons further away from their protons"] than wire A".
Gerry Rzeppa
Joined Jun 17, 2015
170
That may be true, but I don't think the Earth's magnetic field is relevant to the question, since I believe the circuit will behave the same in space, far away from such fields.
dl324
Joined Mar 30, 2015
18,465
Is this school work?
Gerry Rzeppa
Joined Jun 17, 2015
170
No. Well, sort of. I'm a teacher and for several years I've been trying to write an illustrated, cartoon-style book about electricity and electronics for middle- and high-school kids, but I can't seem to pin down a satisfactory answer to this question (which is fundamental to the "picture" of electricity that I want to plant in their minds). One of my inspirations is this book: https://www.amazon.com/dp/0962781592/
35,177
There is no state of equilbrium until infinite time.
Sorry, electrons in a wire don't flow like that. Wire A and wire B will experience the same flow of electrons.
35,177
Then I sincerely suggest that you teach some other subject and not electricity and electronics.
Gerry Rzeppa
Joined Jun 17, 2015
170
Then what is physically different about wires A and B during the discharge period? How do we account for the measurable differences in potential between the two wires during the discharge period? A voltmeter connected to two different points on wire A will read very close to zero potential difference the whole time; but the same meter connected from wire A to wire B will reveal a significant potential difference at the start of the discharge period. What is the physical cause of this potential difference? There must be something different about wires A and B during the period in question. What is it?
Gerry Rzeppa
Joined Jun 17, 2015
170
There is no physical change in the wire. Electrons flow, but the density isn't sufficient to alter the physical characteristics of the wire.
It seems to me that a wire with electrons flowing in a given direction, and a wire with electrons that are not flowing in any particular direction, are physically different. But if the flow is the same in both wires, how do we account for the potential difference between the two?
dl324
Joined Mar 30, 2015
18,465
The capacitor.
Considering the fact that no two wires can be exactly the same, by definition, they're different.
For a typical analysis, we don't deal things at an atomic level. The wire is the same before, during, and after the flow of current. So long as the current density isn't sufficiently high to cause something undesirable, such as electromigration.
dl324
Joined Mar 30, 2015
18,465
I hate the water analogy, but it can be illustrative in this situation...
When an electron leaves the capacitor, it displaces an electron in an atom of the metal in the wire. That causes a "chain reaction" where other atoms give up an electron and almost immediately gain one. So the net number of electrons in any atom of metal remains constant.
Gerry Rzeppa
Joined Jun 17, 2015
170
And all that happens very fast, close to the speed of light, yes? So if the flow of electrons is steady and virtually the same in both wires, how do we account for the measurable potential differences in the wires throughout the hour in question?
Perhaps it will help if we back up a little. You also said that the "the capacitor" was the physical cause of the potential difference. If so, we could think of wires A and B as temporary "extensions" of the capacitor's plates, and the question would then become, What accounts for the potential difference between the two plates inside -- and, by extension, outside of -- the capacitor?
dl324
Joined Mar 30, 2015
18,465
In your circuit, you have two electrical nets. One for the capacitor anode which includes the wire used to connect the anode to one end of the resistor. And one for the cathode of the capacitor. We don't think of the wires as extensions of anything.
We don't think of things happening at the atomic level. That would be an unnecessary complication.
Gerry Rzeppa
Joined Jun 17, 2015
170
Okay, then what accounts for the potential difference between the capacitor's anode and cathode? In other words, what is physically different about the capacitor's anode and cathode when the capacitor is charged to 100 volts?
35,177
Perhaps the answer you are seeking is the electron concentration at wire B is higher than that at wire A.
Wire A and wire B are practically equivalent. We do not consider charge concentration as a physical difference.
