Correct me If I am wrong, When the battery is connected with the conductor. Difference of potential is created due to battery (As positive charges on one side and more negative charges on the other side). This difference of potential created the electric field between the two connectors of the battery as the electric field is defined as the influence of charge around it, so difference of charge creates the influence which cause the electron to move from negative terminal of the battery to the positive terminal of the battery.
My Question is that what is the significance of the Electric field direction in the closed circuit. The direction is mentioned as positive to negative and electrons move in opposite of the electric field. What is the direction significance in this ?
