What is a star ground system?
Fobio Design
Joined May 11, 2016
17
Hello-
Hope you are all having a good day so far. I have a question regarding star ground systems. What is a star ground system? What are the benefits of this system? And how does one go about integrating a star ground system into their circuit? I have attached the schematics of my project.
Thanks for reading and I appreciate the help!
32,887
Basically you run all of your ground (or common) connections back to a single point that then has a very low impedance route back to the source. You often do the same with the power side. The details vary a bit depending on if you are talking about power systems versus something like an analog circuit, but the general idea is the same.
A big advantage, particularly for analog systems, is that the noise associated with the current draw (and variations in the current draw) of one portion of the circuit have a significantly smaller impact on other circuits.
BR-549
Joined Sep 22, 2013
4,931
The whole purpose of a star ground is to keep all circuit grounds at the same potential.
This is accomplished by making sure the ground conductors are the same length.
Lestraveled
Joined May 19, 2014
1,946
The whole purpose of a star ground is to keep all circuit grounds at the same potential............
Wrong. It is to minimize one "leg" effecting another "leg". In other words, a star system minimizes voltage transients, generated by one section, from propagating through out the rest of the circuit.
30,680
IOW to prevent ground loops.
Which also ties in with equi-potential bonding, which mainly applies to electronically controlled machinery and control enclosures.
38,530
An example: Suppose you have a preamp with a high gain driving a power output stage delivering a high current to the load.
If you connect the output load common to a ground line that also is the preamp ground, then the high currents will cause a small voltage drop in the ground resistance at the preamp which will (usually) adversely affect the preamp operation.
Thus you want the preamp ground to have a ground return to the power supply separate from the output stage ground.
The power supply becomes the single point (star) ground point.
