What IC is this? What feature it has?
NVZN1
Joined Dec 17, 2016
35
I found this on Krisbow (brand) rechargeable 4 slot charger MICRO USB.
Powered with 5V Microusb, could charge 4 AA batteries or 4AAA batteries.
But I wonder does this charger is smart chargers or dumb charger forcing to charge without cutoff?
Because I don't see NTC sensors and they don't provide manuals in the packaging.
Only lists this :
Output : AA 1.2V/1000mA
AAA 1.2V/100mA
More details on the pcb:
Ian0
Joined Aug 7, 2020
13,291
The 34063 is an inverting regulator. Originally designed by Motorola, it is now sourced by Onsemi. It is an old design
https://www.onsemi.com/pdf/datasheet/mc34063a-d.pdf
Actually it's a repackaged 78S40 - I think it was introduced as uA78S40 by Fairchild.
If the mystery ICs is a switched-mode regulator, then there would be an inductor in the vicinity.
In the photo there is a diode on pin 2, and current sense resistors connected to pins 1,7 and 8 which correspond to figure 11 in the datasheet.
Papabravo
Joined Feb 24, 2006
22,113
Is it possible the last digit is a "9" instead of a "3"? That would make it a 34069 perhaps.
