I've been dissecting some USB 3.0 cables to try and build a right angle connector. I am both frustrated with and in awe of the glue/resin they use to coat the PCB's in these connectors.
In photo 1 below there is a thick cover of something similar to glue-gun glue but much harder and stiffer which is what I admire about it. It melts under a heat gun and turns clear but cools cloudy and hard again. I'd love to know what it is and how to get it.
In photo 2 below you can see underneath there is an even harder fully clear glue layer like a resin or epoxy. It also looks like a great idea to make connectors more rugged.
Any suggestions for resins / glues with this stiffness and for DIY connector applications much appreciated. Hot-glue just doesn't cut it, too rubbery and I can tear it off with my fingernails.
Thanks!
Thanks!
