What Electronic Component Is This?
Sp@ceR
Joined Mar 11, 2018
50
Hi guys,
I am trying to recap my telephone because of some intermittent hissing noise. Then I came across this component which looked like a shrinked capacitor, but apparently it's not a cap:
The sleeve don't have any rating. I think the word is brand only. Here's the PCB marking:
Can anyone identify the component and what rating should I get as a replacement?
Thanks in advance :)
Moderators note : removed useless space from picture
Sp@ceR
Joined Mar 11, 2018
50
Hi Max,
You are right. There's continuity between the pins. Is there any way to look for the replacement without knowing the inductance value?
DickCappels
Joined Aug 21, 2008
10,661
First of all, why do you want to replace it? If it isn't physically broken, then it probably works fine. It is probably some copper wire around a ceramic core -these things don't fail often.
Often there will be a number stamped on the top of the core, and if this one has that number, that's the value.
MaxHeadRoom
Joined Jul 18, 2013
30,813
Hi Max,
As others have mentioned, probably OK if you see continuity, as an aside, for inductors I usually go to CoilCraft, they have sent me a few free samples in the past.
Max.
28,314
Not only is the device in the pictures an inductor, it is probably a ferrite cored inductor, and unless the material is broken it is OK. If it had suffered an over-current then the heat-shrink would be partly melted. So it is an OK part. If there is an intermittent noise in the phone the fist thing I would check is the microphone conductors in the handset cord, followed by the soldered connections to the modular connectors on the circuit board. That was the problem with one of my phones that became noisy. Resoldering the joints was the solution
Sp@ceR
Joined Mar 11, 2018
50
Thank you all for the replies.
I'm replacing the inductor because one of it has a corroded (rusted) leg, still the continuity tested ok.
@DickCappels I couldn't find any value from the top of the core or bottom of inductor. This is usually how cheap Chinese components are manufactured I guess :D
@MisterBill2 I resoldered the board today with new electrolytic caps (8 in total, replaced 7. I bought one with a wrong value 22uf instead of 2.2uf). Now the noise is not so loud anymore but it's still there and the DC is cut off randomly at the handpiece. I'll have to recheck soldering joints and more deep inspection tomorrow.
AlbertHall
Joined Jun 4, 2014
12,653
The wire is unlikely to be made of anything that would rust.
The picture below shows some enamelled copper wire which the coil will be wound with. Is what you see just a section which has not had the enamelling removed?
Sp@ceR
Joined Mar 11, 2018
50
Albert, the inductor leads I see are just like the normal transistor/ diode leads. They are not copper as you can see below:
Ps: I'm not sure it's rust. Like some sort of black stuff on the leads.
DickCappels
Joined Aug 21, 2008
10,661
You can just (carefully) scrape the leg clean, then thoroughly coat with solder and solder it back in the things are hardy and are not bothered by a little corrosion.
By the way, Sp@ceR, I have hundreds of the very cheapest bobbin inductors (no names on anything) bought in one of the markets in Shenzhen. Absolutely the cheapest parts you can get, and with absolutely the minimum specifications if you can get any at all. These happen to have inductance values stamped on them, but there are probably people out there saying "Trust me, these are 68 uH -here, test one!" There are different ways of doing business the world around.
