GetDeviceInfo
- Joined Jun 7, 2009
- 2,283
There are many aspects to the electrical field. To have higher knowledge in one area, means reduced knowledge in another. An engineer that designs distribution systems may well not know that you have to choose if a relay coil is sunk or sourced. I've gone through the process of spec'ing a full service for a manufacturing plant. I don't know or care if the controls are PLC, relay logic, or manually switched. How big of a transformer do you need to supply an MCC, including wire size, conduit, disconnects, overcurrents, overloads. High voltage is an entirely different animal, requiring specific skills, where low voltage branch to load is a distraction. Also remember that an engineer can spend thier entire career specializing in code interpretation and application.I have read an uncanny amount posts that start out with "I'm an electrical engineer, but...." and end with something like (for example) "how do I use the low current output of a microcontroller to activate a solenoid?"
Having never been to college, I only have my assumtions of what it's like & how it works. My assumption is that something like this would be taught in electrical engineering 101. I just assume that every electrical engineer knows everything there is to know about how electrical things work. Am I wrong? Is it possible that someone could make it all the way through college and earn the title "Electrical Engineer" and not know how to wire a relay?
As mentioned, it's impossible to know everything, and without the expertise of highly trained engineers, we'd still be in the dark ages.
