Wow, first post here. I first posted this in another Zener thread. That was a hijack really. Here's what I'm up to. If you put a zener diode between the center tap of a HV winding and ground on a tube power transformer it will lower the PS voltage by an amount just shy of Vz. Problem is the diode needs to dissapate (say) 210MA at (say) 75 volts. 15.75 watts. The reason for even doing this is to recycle old amplifier transformers (I hate throwing anything away) and most common power tubes really do produce a different tone at different places on the curve. These are guitar amps by the way.
I designed this regulator a million years ago to regulate screen voltage on an AM transmitter modulator tube. Rs bias's the .5w zeners providing a reference voltage for the Darlington transistor that I was using. It worked great. But one thing you don't want in a guitar amp is regulated B+. Things need to sag when you push the amp. It's all part of that elusive "tone" thing. The other two diodes protect the transistor from excessive voltage at B+ reg and in case of zener failure.
Now here's my question. I don't understand Vebo. If you used this circuit as a zener current multiplyer instead of a series regulator could you ground the emitter, or would that let all the smoke out? What I mean here is to wire the transistor with the collector tapped off the HV supply just downstream of the rectifier, before the filter string, with the emitter going to ground. I'm trying to multiply the Pd of the cheap and readily available zeners, substituting a $2 transistor and .10 zener for an incredibly hard to find $25 zener diode. What I will probably do is string three 5 watt 25 volt diodes and jury rig a weird heat sink at the center tap and be done with it.
thanks in advance for replies
Dan H
Dan H
