Weller WS-80 control board schematics ?
Juhahoo
Joined Jun 3, 2019
302
The problem of this Weller is that sometimes the temperature adjustment works normally, but suddenly it just heats up to the maximum and have no adjustment anymore. The solder handle part have been changed from a functioning same model but the problem remains, so the problem must be in this controller board.
I would need a schematics and there are some available online by Google search, but none of those fits to this board. They might be another version or year model.
Schematics should include 16 pin 4053 IC seen in the pic, all of the ones I found did not include it.
Irving
Joined Jan 30, 2016
5,170
That's 23 years old! Chances are its a dry joint on the board, or intermittent wiper on one of the pots. Reflow any joints that look iffy and give the pots a good squirt of contact cleaner, as well as the connector in case its an intermittent temperature sensor connection. If that doesn't help you'll need to reverse engineer the board - it looks relatively easy as only 5 IC (what are they?) and not much hardware for tracks to hide under...
Dodgydave
Joined Jun 22, 2012
11,395
I would measure the voltage across the large temperature preset and wiper , and when it's running check it again, also the voltage signal feeding the opamp from the iron sensor probably a thermocouple.
