This may not be the best forum for what follows, so if anyone knows of a more suitable hardware-oriented forum I'd be kindly obliged for the information.
The 3.5mm audio connector is a well-accepted standard, and a competent design if well manufactured. In my experience most of the plugs, and especially sockets available to hobbyists do not meet this criterion. The reason is easy to discern, and is a geometric challenge in every connector design using curved - especially cylindrical - terminals. Ask yourself: "What is the area of contact between a cylinder and an abutting surface?" The answer is "a geometric line" which is one-dimensional and has ZERO surface area.
The main flaw in the cheaper connectors is a single terminal of thin nickel-plated steel that passes ACROSS the cylinder, thereby reducing the geometric line to a geometric point - nothing. They ALWAYS give unreliable contacts that must be "juggled" in order to get a useful connection. The best available in my experience are the flat ones with a transparent upper case: a quick peek inside shows why.
Does anyone know of a manufacturer with soundly designed 3.5mm products?
