Waveform generator output
kalemaxon89
Joined Oct 12, 2022
389
I was using the function generator in the lab to generate a 50kHz 5V square wave to power a mosfet of a boost converter.
On the generator I have both the "50 ohm impedance" output and the "TTL/CMOS" output ... I tried both and the circuit worked.
But what is the difference between these two?
When to use one and when to use the other?
38,718
The 50 ohm likely has an adjustable voltage output and wave shape.
The TTL/CMOS output likely has a fixed 5V pulse output.
Check the function generator specs to be sure.
DickCappels
Joined Aug 21, 2008
10,662
Also of note is that the 50 Ohm output should be used when driving 50 ohm transmission lines (coaxial cables) the fact that it is 50 Ohms means that it will minimize ringing as a result of reflections, while the TTL output might not be able to drive the cable the cable without much mainly because of the capacitance of the cable.
AnalogKid
Joined Aug 1, 2013
12,245
Another difference is the offset adjustment on the front panel. This usually applies only to the non-TTL output (50 ohm, 600 ohm, whatever). As the name says, it adds a DC offset to the output waveform. In this way, you can cause a square wave output to go from 0 V to +7 V, or -3 V to 0 V, +4 V to -4 V, etc.
The 50 ohm output will be able to source more current than the TTL output. Enough to power a DC/DC converter? Only at a very low power level.
ak
kalemaxon89
Joined Oct 12, 2022
389
ak
Moderator's note: Quote translated from Italian. Please only post in English on this site.
Thank you for the answers.
I don't have the instrument with me at the moment and I don't remember if I could adjust the offset either using the TTL output or the 50 ohm output ... anyway I need a square wave not centered in zero, that is, an offset that brings it to 0-6V (not -3 3V).
So, in your opinion, I should use the non-TTL output (50 ohm, 600 ohm, whatever) to create it.
Am I wrong?
AnalogKid
Joined Aug 1, 2013
12,245
Because that's what the Manufacturer Specs say on the link you posted.
The TTL output can drive 20 standard TTL loads. That is, it can sink 32 mA and source only about 1.6 mA. Also, the high-state output might be as low as 3 V.
With the offset and output adjusted for a peak output voltage of +10 V, the 50 ohm output can produce a peak output current of 200 mA. This is common in function generators.
ak
