Your post does not explain why you don't want the pump to switch on when the level falls a few cm ... you want this tank kept full ??? well the switches you linked to will do that with nothing else .... 100's are sold on ebay for just this situation ... they do work as I described , I have used them!!Oz it would seem that you're suggesting the pump start filling when the upper level goes down a cm...no good for me; more detail given in my update above. Thanks for the response Oz
Do you really think people have all this complication just to keep a tank full up????
You have decided you want it to switch on at a level of your choosing ... unnecessary complication ... All you should want is for the tank to be full within a few cm ... and the float switches in your link will do that. thousands of people use them without problems ... the currents on some of those float switches do seem rather low ..
