Ho wow, you guys give me hope and I thank you all for this help.
oK, Before reading your last posts, I have already removed the connectors from the sensor to the arduino and solder these three wires. I also changed pin to use A5 instead of A0 (just in case). and same problem again. Then reconnecting my jumper stop the problem again.
I also discarded the possibility of noise from the power supply because I already tried on 9v battery and the problem was exactly the same.
I like the "k1ng 1337" point number 2. I think I'll try this first, and then proceed further if required.
I see that you've played with type of sensor too.... I'll have more questions for you once I get this problem solved. I really need stable reading first.Simply put a 0 to 10 PSI becomes 0.5 to 4.5 volt signal.
