Water level detection sensors
arman74
Joined Jul 1, 2017
44
Hi.
I was designing a water level detection device to control the water level.n my application the sensor only needs to act as a switch.I saw another device that had a sensor thing and when it came out of water its temperature and voltage goes up and the MCU commands a relay.But i dont know what is this sensor thing.I think it is a PT.
Whats your idea?
This is a commercial project and the price is important.
Alec_t
Joined Sep 17, 2013
15,155
Can you use a float-switch or pressure-switch?
What is the minimum change in water level that you need to sense?
What are the minimum and maximum levels?
Whether or not a PT/thermistor could work would depend on the temperatures difference, if any, of the water and the environment.
MaxHeadRoom
Joined Jul 18, 2013
30,790
Do you want to monitor water level over all or just a 'Full' level, if the latter, then a simple sealed float switch should work and are generally plentiful.
Max.
arman74
Joined Jul 1, 2017
44
I use it in a saltwater environment and the floater wont work after a while.
Its a switch.When the switch detects low water it turns the pump on for some minutes.
I searched the NTC liquid level detection and I think it works for me.
