Kindly which pins must be connected to to operate the washing machine.
Thanks,,,,,
Thanks,,,,,
Pins 3+5 are main 220 ac volt, can I connect 3+4 or 3+5.... I want to disable the switchPins 3+5 locks the door when power is applied, then when power is removed, the ptc cools down and the lock opens after the set time.
I want to do that to check if the problem is from the switch or from the board, not at all.You will have to take the switch apart to remove the ptc lock, this would render the door lock useless...
