Want to implement a solar powered backpack
fromdawest
Joined Nov 5, 2012
4
I want to design and implement a BACKPACK ( bag ) for travelers with solar power technology included .
My idea is to make a bag, that It can charge the small electronic devices on the move ( when the traveler moves with the bag, lets think he's walking from a place to place with the backpack on his back ) . This simply includes a FLEXIBLE solar panel ( can be found on Ebay ), and a battery bank ( light weight ) inside the bag .
So what I suggest is to charge,
LAPTOPS
Mobile Phones ( any model )
PDA ( any model )
Tabs ( anymodel )
Ipods and MP3 players etc
Please let me know whether this is practical, or are there any suggestion on this project . Please help . :)
Thanks,
Shanuka .
Audioguru
Joined Dec 20, 2007
11,248
A solar powered ANYTHING does not work at night, on cloudy days, in winter when the sun is low in the sky or when the solar panel is not pointing at the sun.
The solar panel should move and follow the sun across the sky in a desert in summer.
18,150
OH ! then i cant make it as a project for my uni .. m sad !
Make wings from your flexible panels and fly an iPhone around with the Facetime camera running. This may have been done also, but I don't think it's commercially available.
One huge problem with these things beyond what AG already identified is simple surface area. You need a lot of area for PV panel even in bright sunlight to give a satisfying amount of juice.
mcgyvr
Joined Oct 15, 2009
5,394
Lawsuits on top of lawsuits on top of lawsuits... here you come...
mcgyvr
Joined Oct 15, 2009
5,394
I just meant from all the people when the iphone plane goes out of control and flies off a cliff or smashes their overpriced phone into pieces on the ground, or scuffs the apple logo, etc...
18,150
Ha ha, yes, there are "collateral damage" concerns, not the least of which could be the phone calls to local authorities about spy plane drones going by their windows. ;)
A solar powered weather station that can get itself onto a cell network to deliver data would be interesting, especially if it could "beam in" a signal better than a typical cellphone, so that it could be used that much farther away.
18,150
Wind power is a good match for an air conditioner, since shaft work for recompression of the coolant is what is needed, not so much electricity per se.
Using solar to make electricity, only to convert that back to mechanical shaft work, is just too inefficient. Old ammonia-based systems use heat to regenerate the ammonia coolant, and I think that type of system could be a good match for solar because there is no need to make electricity. You could just use direct solar heating.
Matching solar to an A/C system would be great since you tend to need a lot more AC when the sun is shining.
I'd love to have a personal cooling system that's more efficient than our human evaporative cooling, and doesn't require dehydration to stay cool. I suppose the DOD must have done some work in this area, maybe elite athletes as well.
Audioguru
Joined Dec 20, 2007
11,248
Hee, hee. The solar panel from a garden light produces a very low current. The little fan driven by the low current is a joke.
