Wanna see something cool #2
cmartinez
Joined Jan 17, 2007
8,844
The gap between the two antennas was not a modest shortfall. The high-gain antenna had been designed to transmit up to about 134,000 bits per second from Jupiter. Through the low-gain antenna, the unmodified rate would have been closer to 10 bits per second.
We used Chlorine Trifluoride to clean PVD process chambers. It saved a huge amount of time per clean.
"It [chlorine trifluoride] is, of course, extremely toxic, but that's the least of the problem. It is hypergolic (spontaneously ignites with) with every known fuel, and so rapidly hypergolic that no ignition delay has ever been measured. It is also hypergolic with such things as cloth, wood, and test engineers, not to mention asbestos, sand, and water—with which it reacts explosively. It can be kept in some of the ordinary structural metals—steel, copper, aluminum, etc.—because of the formation of a thin film of insoluble metal fluoride that protects the bulk of the metal, just as the invisible coat of oxide on aluminum keeps it from burning up in the atmosphere. If, however, this coat is melted or scrubbed off, and has no chance to reform, the operator is confronted with the problem of coping with a metal-fluorine fire. For dealing with this situation, I have always recommended a good pair of running shoes.
-- John Clark, Ignition!: An informal history of liquid rocket propellants"
