I have a computer monitor that is missing the power cord and it says it needs 19v with 6 amps. I have a 19v with 3 Amps what can I do to make it 6 amps ?
Nothing.I have a 19v with 3 Amps what can I do to make it 6 amps ?
If that is 19VDC and not AC, look for a power brick from a laptop rated to 120W or more. Most are ~19VDC.I have a computer monitor that is missing the power cord and it says it needs 19v with 6 amps. I have a 19v with 3 Amps what can I do to make it 6 amps ?
Your only option is to buy a different supply.I have a 19v with 3 Amps what can I do to make it 6 amps ?
Well, you could use a buck converter to lower the voltage to 9V at 6A, but that won’t help much.I have a computer monitor that is missing the power cord and it says it needs 19v with 6 amps. I have a 19v with 3 Amps what can I do to make it 6 amps ?
by Jake Hertz
by Jake Hertz
by Jake Hertz
