I have a problem, In the following circuit,
I have a voltage regulator with a selector that chooses between different resistor values to make different voltages.
But if ever the selector malfunctions or when changing, it will be disconnected, so the circuit will be open and the voltage regulator will send the maximum voltage, which may burn the thing connected at the output.
I haven't figured out how to solve this problem,
do you have an idea?
![Capture d’écran 2024-06-25 140006.png Capture d’écran 2024-06-25 140006.png](https://forum.allaboutcircuits.com/data/attachments/313/313046-d103eb336420e25c48da60607eedc840.jpg)
